Zenith O-Rings Help
I'm rebuilding the Zenith 40 TINs for my 1970 911T using the rebuild kit from our host. The kit has many o-rings of different sizes, but I only found o-rings on the idle mixture screws, the injectors and each of the auxiliary enrichment circuit housings. Should there be o-rings on any of the other parts (e.g., idle jets, values, etc)?
1969 912/6 Coupe
1970 911 T Targa
Old 07-28-2007, 08:56 PM
I think that's all I have for o-rings. I guess the kits could cost less if they gave what you actually needed. Assuming we don't need the rest.
Old 07-29-2007, 04:01 AM
rw7810's Avatar
C4 Pazzo - I need a couple of mixture screw o-rings, any chance you could send me a few of you old ones ??
Robert Williams
70' 911T
Old 07-29-2007, 08:39 AM
AllenK - Thanks for the info. The only other spot that looks like an o-ring might make sense is the idle jets, but the ones in the kit don't seem to fit over the jet.
rw7810 - I used the all the o-rings that fit the mixture screws. The remaining ones would be too big. Sorry.
1969 912/6 Coupe
1970 911 T Targa
Old 07-29-2007, 09:01 PM
