SP2 SP2 is offline
SP2's Avatar
Driving it without the heater blower?
I had to take out the heater blower and now I can't get it back in, at least not quickly. This is an 81SC with CIS. So now I have the two hoses from the heat exchanger and the hole from the alternator fan sitting there with nothing attached. Can I still drive the car like this? The heat exchanger hoses normally receive air, they don't blow hot air into the engine bay (I think).
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 05-14-2006, 06:08 PM
Block off the left air horn duct so you wont lose cooling air over cylinders 1-2-3, no problem driving after that.
John Adams
1980 ROW 911SC
Old 05-14-2006, 06:52 PM
SP2 SP2 is offline
SP2's Avatar
Hi John,
Thanks, but I am not sure what the left air horn duct is. Is it one of the hoses coming off the left heat exchanger (and plugged into the blower motor?
James
1981 911SC Wine Red
Old 05-14-2006, 07:14 PM
Paper Member
It's where the big black plastic hose comes out of the shroud and goes into the center of the blower you're removing.
Enemy of the State
Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it.
Old 05-14-2006, 07:30 PM
SP2 SP2 is offline
SP2's Avatar
I took that hose off. But there is a lot of air coming out of that shroud. Still ok?
James
1981 911SC Wine Red
Old 05-14-2006, 08:15 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
I drove my car for years without the hose on. no problems. Just cap the hole to keep the air flowing over the l/s of the motor. I finally decided to clean up the engine bay so I just installed the blockoff plate from our host since the blower is gone.
Air Block-Off Plate, Left, Fiberglass, 911 (1965-89) [Photo]
PEL-PP910181 $88.50
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 05-15-2006, 01:50 AM
Paper Member
No, you're losing cooling air unless you block off per Scotitude's method with the block-off plate.
Enemy of the State
Old 05-15-2006, 05:35 AM
JBO JBO is offline
...or you cover the hole with metal tape or a tuna can, which is the perfect size, which accomplishes the same thing as the $88 block off plate, though it doesn't look as good...
Old 05-15-2006, 07:30 AM
SP2 SP2 is offline
SP2's Avatar
What if I powder coat the tuna can? Which brand? Chicken of the sea anyone?
Just kidding. I like to have fun with this project of mine. I think I will backdate my heat.
James
1981 911SC Wine Red
Old 05-15-2006, 09:49 AM
Careful of the brand! This is very important - DO NOT GET THE 'PEELABLE' CANS. It has to be one you need a can opener for.
Whew, disaster averted (barely).
Babak
Old 07-09-2007, 11:37 PM
JK-81SC's Avatar
Go for the back date. It gets rid of that ugly paper hose running across the engine, and gives you a much cleaner look. Easier to work on the engine too, once all the stuff is gone. If you want a picture do a search, or I can take a pic tonight and post it tomorrow.
Jeff
1981 911SC Coupe - SSI's + Dansk, MSD, AC delete, Heater Backdate, Euro ride height, polygraphite bushings, Rennshift
1998 F-150 4x4 - Snow Time
1998 Yamaha WR400 - Mountain Ride
Old 07-10-2007, 12:34 PM
ianc's Avatar
True, and the heat\defrost doesn't work worth crap at low speed anymore, but hey, it looks good.
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 07-10-2007, 11:04 PM
JK-81SC's Avatar
My blower motor was seized up and not working anymore. By back dating the heater design I got better air flow. I supposed if I had a working system, I may have left it as it's ugly self.
I use my heater with SSI's in Colorado and have never been lacking heat. The SSI's put out so much heat, I can't pull the heater levers more than 1/2 way.
Jeff
Old 07-11-2007, 07:58 AM
