-   -   86 Carrera... improving shifting (http://forums.pelicanparts.com/porsche-911-technical-forum/356681-86-carrera-improving-shifting.html)
Porsche_monkey 07-11-2007 10:47 AM
Mine broke here:
http://forums.pelicanparts.com/uploa...1184176051.jpg
notfarnow 07-11-2007 10:57 AM
That's an epoxied joint too, isn't it?
Porsche_monkey 07-11-2007 10:58 AM
Not anymore. Mine is welded.
notfarnow 07-11-2007 11:03 AM
OK, moving along...
What about "flipping" the engine/tranny mounts. Anyone done this? One pelican claimed a significant improvement:
http://forums.pelicanparts.com/newreply.php?action=newreply&postid=2785337
Originally posted by stealthn
One tip that was amazing for me was my mechanic flipped my motor mounts and I can not believe the difference in the shifting. It is firm as can be now.
I bought the shifter bushings to replace, and after he did the motor mount flip I don't need to...
I cannot tell you what a difference it made!! the shifting is firm and straight with no side to side flop. If you want an inexpensive way to firm up the shifter flip the motor mounts.
Nuff said
450knotOffice 07-11-2007 11:12 AM
I got all new mounts front and back. Only a slight improvement.
Porsche_monkey 07-11-2007 11:16 AM
Flipping them strikes me as unlikely and new bushing fall into the same category.
My car has 150,000 miles original engine and tranny bushings, but it is properly adjusted and the coupling has been rebuilt. It shifts very nicely.
notfarnow 07-11-2007 11:23 AM
ya this car only has 69,000 miles. The previous owner only drove it ~2000 miles in 3 years. We've put 2k on it in the past 2 months.... I think we're just "rattling" out any issues.
Who'da thunk PPOT would know so much about porches?
- Technical content: Check
- Political references: Check
- Cute girly in bunny outfit: Check
- Global warming debate: Check
The only thing I'm missing is a one-star thread rating.
Gene Wilkes 07-11-2007 11:33 AM
If you don't do the jacking up the transmission route, you'll need to remove the parking brake assy and it will come out there. Slide the rod all the way forward and pull it out towards the back seats. Once you have it lined up, and turning it as you remove it, comes right out! Helps to have the passenger seat out too!
450knotOffice 07-11-2007 03:59 PM
Bump back to the top and hopefully into the tech forum where Jake can get more responses.
notfarnow 07-11-2007 04:36 PM
Bull$hit! you just wanted to delete you admission to giving this a one star rating!! lol
Dad managed to pick up the two front bushings this afternoon. I'll throw them in this weekend, and have a look at the coupler bushings. The shop wanted to sell him a new coupler, but I'd just as soon hold off, and then press in new brass bushings if needed.
Jims5543 07-11-2007 05:10 PM
This tech article was posted in a shifting thread and a lot of people said it works wonders.
http://www.pelicanparts.com/techarticles/911_shifting_improvements/911_shifting_improvements.htm
450knotOffice 07-11-2007 05:20 PM
Nah, I was just having fun with you. You said that was all you needed to make this thread complete, so I helped you out. ;)
Good luck with the bushings, Jake. SmileWavy
notfarnow 07-12-2007 07:22 AM
Thanks! They seem pretty straightforward. I'm a bit bummed about having to pull the console again. Maybe I was doing something wrong, but I had a heck of a time struggling with the wiring for the AC, central locks & emergency flasher. Can I remove the console without undoing all that stuff?
Also, I emailed the PO and apparently I was wrong about the car having Swepco lube. I'll add that to the list for fall maintenance.
Christien 07-12-2007 07:26 AM
Screw buying a new coupler. My favourite saying is "if I can do it, anyone can" and I did it. Just do some reading here on getting the new bushings in - I used a socket to apply pressure to the bushing and squeezed it in using a vice. Once I figured out how to get it in, it took a couple of minutes.
notfarnow 07-12-2007 07:32 AM
That's what I'm thinking too. I'd sooner press brass bushings into the coupler than have a new coupler with plastic bushings.
Just the same, I think I'll start with those two shifter bushings. I'll have a look at the coupler, and if it's wiggly I'll press in new bushings when I have the car again later in the summer. At that stage, I'll probably do engine & tranny mounts too.
Porsche_monkey 07-12-2007 07:58 AM
My coupler:
http://forums.pelicanparts.com/uploa...1184252282.jpg
notfarnow 07-12-2007 08:17 AM
Is that a homemade one? I saw a few threads about using universal couplers from Aircraft Spruce, and drilling/tapping a setscrew. I couldn't find the specific part # though.
Scott R 07-12-2007 08:33 AM
Sorry, back, damn job. Yes I was able to get #25 (the long shaft in the tunnel) out by jacking up the transmission and removing the cross member. It was a tight fit, but it does come out by twisting it. I cleaned up the end and aligned the stub piece on the shaft, then welded with my MIG using high amp and stainless wire.
It's an amazing fix, night and day. I can only guess that the PO had the shift coupler out of alignment and he was forcing the shifter around, and broke the now identified epoxy. Like I said in my previous post I can't understand why the factory did this, a billet shaft would have been a better choice IMHO.
Porsche_monkey 07-12-2007 11:02 AM
Does it look home-made? (I made it in myself, but not at home). ;)
notfarnow 07-12-2007 11:25 AM
Well, not "homemade" by my standards.
I guess "homemade" can mean a lot of different things, depending on whether you have a lathe, welder, or beer on your breath.
When I was 17, I replaced the shift linkage in my Lecar with a bike pedal, pedal arm and 4 hose clamps. I once had it in a Renault-only shop in Montreal, and when they drove it they asked me what "short shift" kit I used. They sure laughed when I showed them.
