how much does it weigh?
I was considering pulling the rear carpet up and seat and removing all that nasty brown insulation underneath that and the rear shelf. whats that stuff weigh? Gotta be worth something .. but with that removed how much louder will it be inside?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 06-29-2007, 05:53 AM
I'm curious too...
Old 06-29-2007, 05:57 AM
Porsche Crest How Much????
Hey Ben,
Believe it or not....
That stuff weighs between 40-45lbs.
I could not believe it myself.
My example was a 79 930.
So any SC...or 84-89 Carrera should be the same.
However, on the advice of Jeff Erickson (AASE Motors, Fullerton CA), I put the insulation back in. He informed me...the weight savings would not be worth the BIG increase in noise for a STREET car. However...on a track car....it makes great sense.
Hey....BTW...I received the insert for my M & K...
It did help.
Thanks...
Paul
1970 911 (SLVR/BLK/SRD)
930 RSR in "Excellence" Sept 2007 (SOLD)
1983 911SC EURO (SOLD)
Old 06-29-2007, 06:42 AM
rdane's Avatar
'79 here and same weight drop, 40/45 lb. A lot more noise. But a new engine sound pad from Pelican will cut most of it. Dyna mat the interior if required for less than 10# and less noise than the original version. Some have used the sound reduction paint to good effect as well.
Old 06-29-2007, 06:58 AM
MFORCE
JoeyJoeJoe's Avatar
I just removed the sound deadening material from the back deck and the seats....all total it weighed approx 45pds...plus I removed the back seats which was another 10.....to be honest the increase in sound from the engine is not much....plus who wouldn't want to hear it!
45 pds on its own will not make much difference in terms of performance but if you are stripping out other things...it is a big part of lightening the car.
1985 3.2 Carrera Turbo Targa
Old 06-29-2007, 07:02 AM
Non Compos Mentis
Mine is gone, along with the sound pad. I don't think the car is too noisy, but it's not my daily driver. The car has no radio, so the engine is all there is to listen to.
I'm afraid I'm past the point of no return Any tips/suggestions from you guys that have already succombed to this sickness....
Old 06-29-2007, 07:08 AM
MFORCE
JoeyJoeJoe's Avatar
My goal was to lighten the car as much as possible while still haveing it look stock.
remove doorskin hardware, buy an M&K muffler it is very light, buy headers (if you don't need heat) , remove AC, remove heater blower motor, remove carpet backing, remove sound deading material on floor and under car, light seats, fibergalss bumpers, hollow torsion bars, remove rear seats and sound deadening....there is more but after the big stuff it gets expensive. I probably missed stuff but that's my list
Old 06-29-2007, 07:15 AM
I'm sorry I wasn't clear... I've already done a bunch of that stuff Joe, I was asking specifically about removing & cleanup of the insulation stuff.
Old 06-29-2007, 07:22 AM
well mine is coming out then for sure
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-29-2007, 08:30 AM
rdane's Avatar
Adding a set of lwt race buckets, deleting the sound pad and rear seats can net you a 100# loss if you are careful buying and selecting the hardware for installing the new seats.
Old 06-29-2007, 08:53 AM
Senior Member
Superman's Avatar
That pad is coming out of my car. Ounces add to pounds. 45 lbs is large! I am not afraid of the sound of my engine. My car has a radio, but it gets used almost never.
Mocha 1978 911SC. "Coco"
Old 06-29-2007, 09:57 AM
I just hate dealing with the stuff. its so messy when running my wiring through (ecu and MSD) I want to dump it..
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-29-2007, 01:00 PM
well the answer is 30 lbs thought some would be interested
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-29-2007, 08:34 PM
randywebb's Avatar
On a 1977 911, the rear carpet + seat + all the brown insulation underneath the seat and rear shelf area = 30 lbs. ?
Or is it some subset of that?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-29-2007, 10:31 PM
rdane's Avatar
In my car there was a big "rubber" sound matt that was molded to shape of the rear section of the car in addition to everything else you have mentioned Randy and the rear seat belts.
Old 06-29-2007, 10:44 PM
seats are staying in along with the carpet but all the insulation was 30 lbs
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-30-2007, 05:26 AM
DUK DUK is offline
DUK's Avatar
Just poking fun here. I'm pretty sure Ben has an M&K.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 06-30-2007, 08:47 AM
MFORCE
JoeyJoeJoe's Avatar
haha....didn't notice who it was from..lol..ya me thinks he may one or two
Old 06-30-2007, 09:39 AM
yeah I have this M&K setup so 30lbs drop makes up for the extra weight
Ben
89 944,85.5 944
914-6werkshop.com
Old 06-30-2007, 10:33 AM
