MSD question
Is there a way to check the RPM modules? I have a 6000RPM chip in mine and it has no effect on limiting the RPM. Is there a way to check the chip?
Did you clip the red wire located under the little black cap on the side of the MSD unit? . This lets the MSD fire on 6 cylinders. They come ready for 8 cylinder set up. I had the same problem befor I did this.Refer to page 3 on MSD info Cheers Chuck
| All times are GMT -8. The time now is 07:13 PM. |
