-   -   Problem with valve adjustment (http://forums.pelicanparts.com/porsche-911-technical-forum/357185-problem-valve-adjustment.html)
Scott98 07-14-2007 10:49 AM
I'm currently in the middle of adjusting my valves. I'm on the #4 intake valve. I loostened the 13mm nut and now the screw won't turn back unless I apply a lot of force with the screwdriver. The number 4 exhaust screw loostened up without a problem. What's going on here?
Thanks,
Scott
Eagledriver 07-14-2007 08:46 PM
Sometimes the screw stretches because the locking nut has been tightened too much. You can live with it or replace it. If you can still get a proper adjustment I'd live with it.
-Andy
Hugh R 07-14-2007 09:15 PM
Maybe you have pressure on the tappet, meaning its not at TDC.
