Missing at start-up
I have tried using the search key to solve my problem but I just can't find my situation. When I start the car cold and attempt to accelerate the engine will not fire. It sputters and just won't go. If I rev the engine, it will rev but if I hold at a constant RPM it sputters. This goes on for about 4 or 5 minutes then I hear a mild pop and the engine runs perfectly from then on. What gives? Any advice. Thanks.
'84 911 Targa |
911 user...
check fuel line connections to make sure they are tight; you may be leaking presure. It's free anyway and should be checked everyonce and a while. especially the clamps that go from fuel pump to tank. Does the car start up fine after driving for some time or when it's warm?
-Will 911SC & Audi S4 Count those blessings every night! |
Yes. Once the car gets past this initial problem at start up, it runs and starts just fine from that point on. I guess I should also mention that I drive it only once or twice a month and it sits in my garage most of the time.
'84 911 Targa |
