New (to me) 911 door question
I just bought a 1986 low mileage 911 Carrera. The car is in excellent condition but I have a question. The door latch mechanism has a two stage operation. On my car you need to solidly shut (almost slam) the door to get either door to engage this second stage on the latch. Is this an adjustment I need to make or are all 911's like that?
Here is my new car:
Old 07-17-2007, 07:23 AM
Born to Lose, Live to Win
ramonesfreak's Avatar
nice car. my doors require the same strong effort to fully close. seems normal
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 07-17-2007, 07:31 AM
dlagerstrom's Avatar
Welcome!!
Very nice looking car. Sweet, as my daughter would say.
I have never had to slam the doors. Probably something out of whack. Try doing a search on door adjustment.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 07-17-2007, 07:35 AM
cycling has-been
bkreigsr's Avatar
nice ride Ray, I just helped a buddy score a 85 targa and was very impressed with how that generation 911 gets around.
The striker bolt receiver assembly on the door jamb is adjustable. Pelican sells the special 12 point hex wrench to get the job done (as does Snap-On, Mac, Matco, Craftsman, etc.). Trial and error is the best way to determine where the proper location will be. The door should close with one firm clunk/twang motion. Sounds like yours is positioned too far inboard.
Bill K
Old 07-17-2007, 07:37 AM
TroyGT's Avatar
I have an 86 as well... but I'm not sure exactly what you mean by the two stage latch. Do you mean the door is caught... but you can still flop it in and out a little? I'm assuming that you can see an obvious crack in the door while in this semi-latched state? My car closes fine with a normal push... not really a slam. I can't, however, just hold the handle and push it to.. like some of my other cars. You could just need a latch adjustment... some lubrication... or your car is really air tight and it just doesn't close easily because of that (which is good). Crack the windows and try shutting it a few times... see what happens. If that doesn't change... inspect the hinges and the lock mechanism. Lube and re-test.. then report your findings.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 07-17-2007, 07:38 AM
Designer King
Paulporsche's Avatar
There is a white plastic piece about half inch thick sandwiched behind the steel of the door catch, on the post @ the rear of the door. Make sure that piece has not split and a piece slipped out of position.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-17-2007, 03:39 PM
