-   -   Upgrade available for Black Widow Keyless Entry Systems (http://forums.pelicanparts.com/porsche-911-technical-forum/357447-upgrade-available-black-widow-keyless-entry-systems.html)
mthomas58 07-16-2007 11:29 AM
Called Black Widow technical support last week to see if it would be possible to extend the antenna wire to get better range with the remote.
The answer was no. HOWEVER, I found out that BW makes an extended range antenna. Cover pops off, old antenna lead is unpluged and new one plugs in. Part is ERM1 or ERM2 (two diff models - cosmetic not functional diff as I understood)
These part #'s do not show on BW's website, you've got to call to order. I've got one on order and will post a follow-up with the results. Part cost is $8.00
Install Thread:
http://forums.pelicanparts.com/showthread.php?s=&threadid=304308&highlight=keyles s+entry
Web Site:
http://www.blackwidowsecurity.com/products.htm
