T77911S's Avatar
clutch chatter in 1st
what are some of the causes of clutch chatter? hot spots on flywheel? broken spring on disk?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-16-2007, 09:47 PM
#1 cause is a worn clutch disk.
Oil leaking onto the clutch
Soft or broken motor / transmission mounts
Loose transmission to engine mounting bolts
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 07-17-2007, 04:20 AM
sithot's Avatar
All of the above.
Tom
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 07-17-2007, 06:12 AM
Senior Member
Superman's Avatar
I recently replaced mine, which was chattering. It was also a bit contaminated with oil. John Walker's observation that rear main seals almost never leak is certainly reliable. Indeed, if the rear main seal did leak, the flywheel would throw that oil out onto the bellhousing anyway, instead of onto the disk. Clutch disks get contaminated from transmission oil crawling up the tranny input shaft. I replaced that seal. In fact, I installed the new seal in a slightly different position to keep it from rubbing on the part of the input shaft that was showing some wear from past seals.
Mocha 1978 911SC. "Coco"
Old 07-17-2007, 08:26 AM
ttweed's Avatar
It can also be something as simple as the clutch cable adjustment and preload of the Bowden tube.
TT
Tom Tweed
Early S Registry #257
R Gruppe #232
Rennlist Founding Member #990416-1164
Driving Porsches since 1964
Old 07-17-2007, 08:58 AM
