Jaz Jaz is offline
Jaz's Avatar
911 SC tyre pressures for 18" all round
Hi Guys,
What's the recommended tyre pressures for a SC,
I'm running 18" wheels all round, (fronts on 225x40x18" &
rears 265 x35 x18") furthermore wanting to improve fuel economy ( currently getting 23.71mpg) , any advise much appreciated.
Regards,
Jaz
http://www.juswant.btinternet.co.uk
Old 07-19-2007, 01:44 AM
you see Arthur...
jasonlee's Avatar
As the 18" wheels and tires are not stock, I would go based on what the tire specifies for pressure. Ususlly the sidewall of the tire provides a range of acceptable tire pressures. If you fill your tires closer to the upper end of the range, your already harsh ride with 18" will definitely be more pronounced, with a marginal increase in fuel economy. Just my 0.02
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 07-19-2007, 11:20 AM
