G50 Diff bearing "Sudden Death"
Hello guys!
I remove the bearings from a diff and the puller make this happen :
What do you think can be re-used ?
If no what brand to buy FAG,SKF,TIMKEN ?
Also do I need to check backlash ???
T H A N K S
Old 08-23-2007, 02:01 PM
you distorted the spacer cage with the puller. if you can carefully restore it to look straight again, you probably can reuse it. otherwise, it doesn't matter which brand you buy, bearings are all the same for that application. no real need to adjust or check backlash, because....., they're all the same.
206 637 4071
Old 08-23-2007, 03:31 PM
Question
Thank you very much John!
And another question diff related.
Which diff bolts do you guys prefer the 964< with secure clips or the > 993 w/o ???
Thank you all !
Old 08-23-2007, 05:04 PM
