-   -   POLL: Which Engine Management System is best? (http://forums.pelicanparts.com/porsche-911-technical-forum/357848-poll-engine-management-system-best.html)
David 07-20-2007 07:06 AM
Originally posted by herman maire
Would a M48 system been enough for your car? I thought the M600 was expensive almost overkill for a street car because it had fancy features like
-ignition cut out for sequential gear boxes
- traction control
- Data loging ect...
features not needed on our old cars.
the M48 is only like $2400 also... not to bad if it does the job.
I think most people still use the M48 even on high end projects, I used the M600 for the additional ignition outputs, but it could be done cheaper with an ignition expander.
