dweymer's Avatar
carbs for a 2.7
I am thinking of changing to carbs on my 2.7 so I can run a hotter cam. What would be a good baseline start as far as size, jets etc. I would bolt them on to my engine which currently has SC cams in it to make sure everything works, then pull the engine and swap cams. So I would need a setup to work in those parameters. Not sure on final cam choice yet.
Donnie
Currently Porsche-less.....
Old 07-19-2007, 07:50 AM
Donnie:
The real limitation in cam choices in a CIS engine are the pistons.
Unless you change those to ones with double valve reliefs, you are stuck using the 964 cams.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-19-2007, 08:14 AM
dweymer's Avatar
will the 964 cams cause reverb on the airflow sensor plate in the CIS air meter?
I knew I should have changed pistons when I rebuilt it!
Donnie
Old 07-19-2007, 08:35 AM
964 cams are the most aggressive ones that are still compatible with CIS,......
No worries, sir.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 07-19-2007, 09:31 AM
I would rather be driving
jpnovak's Avatar
Steve, I have heard read on the engine board that a 964 cam will not clear the 2.7 CIS piston dome. I presume on the exhaust side. Can you confirm? It would be good information for the board. I am not sure if this is the 2.7 or the 2.7S piston.
Donnie. YOu could have valve pockets machined into your CIS pistons.
Old 07-19-2007, 09:42 AM
dweymer's Avatar
I am going to have to buy a mill to stay in this game
Donnie
Old 07-19-2007, 09:43 AM
