-   -   Where to get this diagnostic tool?? (http://forums.pelicanparts.com/porsche-911-technical-forum/357856-where-get-diagnostic-tool.html)
mmasse 07-18-2007 04:04 PM
Does anyone knows where can I buy this diagnostic test lead? I would prefer an online source.Thankshttp://forums.pelicanparts.com/uploa...1184799863.jpg
mmasse 07-19-2007 07:47 AM
Anyone?? maybe someone knows where to get these connectors ...or even the name of the connectors??
Wil Ferch 07-19-2007 07:51 AM
Mario:
If you gave some more information , such as where you got the diagram and what it is you're trying to do...maybe others here can help better.
Regards,
- Wil
mmasse 07-19-2007 08:40 AM
Thanks Wil...you ara right.
I got the diagram fro the Porsche Workshop manual. It is a test lead to connect to, for example, the ISV connector so you can check the signal while the ISV is running. You can also use to check for Throttle Position Sensor (TPS) operation, or any other sensor using the type of connector. I am not sure if this test lead is being sold as shown in the picture...or if the repair shop is supposed to fabricate it, since the Workshop manual metions "shop-made test lead" in some places.
I could fabricate it without problem, but I dont know where to get the connectors from.
Hope this makes it more clear.
Thanks again
donporfi 07-19-2007 10:11 AM
Mario:
Check at www.eagleday.com for the connectors.
