Speedo Millage counter stop working
I notice today that my millage hasn't change in about 2 weeks..Last i noted it was 125,348 and now it stop at 125,355 and hasn't changed. I took notice to this because i realized that my trip counter hasn't change after a reset. Has anyone had this problem? New Speedometer's are EXPENSIVE! I have the us version, with the max speed at 85.
Thanks! |
As long as it's connected it should work, but they have gears and gears break. NorthHollywood speedo is a good one for replacement gears.
odometergears.com
I repaired it myself with the gear from them, as have many others here. |
Same here... I ordered odometergears.com They'll probably have what you need. Pull the speedo and open it up for a look. Mine looked exactly like the picture shown on odometergears.com's website. The flaw... so I'm told... was that the gears were greased from the factory with a new grease type that they learned actually breaks the nylon gear down over time... turns it to mush. Mine came out in many, many pieces.
-Troy |
been there, done that
Yes, while the plastic odo gear is not all that hard of a repair, I think I'd cruise the classified ads here & on ebay and just buy a used speedometer and ditch the 85 mph version.
nhspeedo.com will fix it for you, and if you want, they can turn your speedo into a 150mph version, if you like. Or 180, or 250, or . . . . . .
| All times are GMT -8. The time now is 03:11 PM. |
