-   -   help removed my er brake handle cant grt the cables back on (http://forums.pelicanparts.com/porsche-911-technical-forum/358045-help-removed-my-er-brake-handle-cant-grt-cables-back.html)
pinto096 07-19-2007 05:45 PM
cant find a way to put the cables back on the equalizer tried all day seperated the er cables from the hub what is the trick before i bring it to porsche to put it together thks
Mo_Gearhead 07-19-2007 07:08 PM
Not sure which year your car is? Assuming they are all similar...
you will not like my suggestion. You will need to take them loose at the brake ends to get enough length to work with.
I fought this on mine for an hour before getting them in, mostly because of little space to work ...and I had not yet put my seats in or hooked them up at the brake end!
Sorry , perhaps someone else has a secret trick???
pinto096 07-19-2007 07:13 PM
the lines are disconnected and yes the hole is small worked at it all day cant get it in the 2 holes man i wish i never touched it
