Need help to identify transmission numbers
Have a transmission 7321101 and need to know if it matches my motor. 6321204 does any one know how to do this.
engine 72S 2.4 MFI trans 72 E and S 915-02
Well, it is the correct year, and the 1101 is close to the 1204 considering the engines & trans were in different series, and were mixed and matched independently. The only way to know for sure is to contact PCNA and ask. However the records they currently use probably do not have the trans info.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
gearhead
Not to hijack, but Dave, maybe you can answer this. I've seen the same pattern a few times where the COA doesn't know the gearbox number. Any ideas why?
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks for the information and your time greatly appreciated
Matt, I asked my factory source for a Kardex for a 1970; coincidentally one VIN removed from a known Kardex. They would not provide the Kardex but offer the same info as found on the COA; without date or trans. So whatever data file the factory & PCNA currently use, it is lacking in important information; or they have very strict orders to use only a portion of the data. The older COA (say 10 years ago) did have more info than the newer ones.
