timing help
hi guys need some help with igition timing.
how do i set ignition timing and what should it be on my engine with the following spec. 1. 2.7 JE 95:5 piston 2 weber 40 IDA 3 S cam 4 SSI 5 MSD 6A thanks again for your help. regards |
I'd be pleased to offer instructions and timing values but I need to know what octane gas you use,...:)
Thanks stve! i am using 95 (ron) octane here in Thailand
regards |
posting steve answer here since he help me in early registry. in case some one search this up.
Originally Posted by Steve@Rennsport Thank you,... Assuming that you have a timing light and that your point gap is spot on, loosen the distributor hold-down and rev the motor to 6K for a brief moment while turning the distributor to get 30 degrees total timing. The timing marks are on the lower crank pulley, as you know. It might take a few tries to hit the 30 degree mark and don't forget to tighten the distributor hold-down after you are done. Thats a conservative number for your hot weather. Hope this helps, |
| All times are GMT -8. The time now is 08:36 PM. |
