maxporsche's Avatar
brake line trouble
I managed to remove 3 calipers using a flare wrench, the 4th (LR) is stuck and I'm afraid I may have worn the nut's corners, I used WD-40 and let is sit overnight, allowing my temper to unwind, I was thinking of using a file to chase the edge, using a sm. vice grip with a flat jaw, and was wondering if I should try to heat the caliper? I worry about heating and flammability, can I freeze the line? Any thoughts?
Old 07-21-2007, 08:41 AM
Somatic Negative Optimist
Gunter's Avatar
WD-40 is NOT a penetrating oil.
Get the right stuff, soak it, then use a Vice-Grip.
Some heat is good on the caliper around the nipple, NOT on the nipple.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 07-21-2007, 08:57 AM
AutoBahned
RWebb's Avatar
use Kroil, pb Blaster, etc.
Old 07-21-2007, 10:47 AM
maxporsche's Avatar
PB Blaster and visegrips worked like a charm in 5 minutes!! Thx for info
Old 07-21-2007, 04:18 PM
