arbita1's Avatar
Removing Evaporator and Blower Assembly
I'm trying to remove the evaporator/blower assembly from the smugglers box, but I can't seem to get it out. I've removed all the supports per the Bentley Manual.
Is there any trick to this? It seems stuck in there even though I can shift it around in the smugglers box.
Matt.
83 911SC
85.5 944 NA - Sold
Old 07-21-2007, 07:28 AM
Have you removed the air inlet attachment flange under the passenger side floor board?
Old 07-21-2007, 07:40 AM
arbita1's Avatar
No. Unless I missed it, Bentley doesn't tell you to do that.
Matt.
83 911SC
85.5 944 NA - Sold
Old 07-21-2007, 07:52 AM
Bentley isn't a comprehensive manual especially in regards to AC. You must remove the flange to extract the evaporator/blower housing.
Old 07-21-2007, 07:59 AM
arbita1's Avatar
Can you give me an idea what it looks like. I opened up the floor board but I'm not really sure.
Also, turns out I have an amplifier in their. Lol.
Matt.
83 911SC
85.5 944 NA - Sold
Old 07-21-2007, 09:45 AM
small plastic flange about 3" to 4 " wide and 3" deep held on by 4 sheet metal screws which mave have a resistor setup in it
83 SC
Old 07-21-2007, 11:14 AM
Gasoline User
1974carrera's Avatar
You can see the flange in this pic. Remove the 4 perimeter screws and screen; then withdraw the flange. If everything else (don't forget the capillary tube) is disconnected you should then be able to remove the evaporator box up out of the smugglers box.
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 07-21-2007, 01:10 PM
