Purpose plastic caps brakebooster foot
Hi,
Can someone explain the purpose of the plastic caps in the foot of the brake-booster, there are two see picture, may they be removed ? http://www.pelicanparts.com/techarticles/911_master_cylinder/pic9.jpg The 17mm bolt is this the one that holds the bar that is going to the pedal cluster ? Thanks, Peter Last edited by PeterTarga; 07-21-2007 at 03:35 PM.. |
Diss Member
It simply seals the passenger compartment from the trunk area.
Also pretty low risk but it could be bad if something like a tool floating around your trunk jammed into the brake linkage.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Thanks Quicksilver,
My question was maybe not so clear but when you remove these caps do you have access to something (bolts/nuts), should i remove these to have access to the nut of the brace ? Peter |
When you reinstall your master cylinder you can use your finger to help put the bar in place to accept the bolt. I don't think there is a nut in there, it either threads into the bar or the nut is welded to the bar.
Tony G 2000 Boxster S |
