Paul K's Avatar
930s steering wheel install questions...
Hi Guys:
Is there anything I need to know before I install a 930s wheel on my '89 3.2? It didn't come with instructions, so if anyone has done this, step-by-step instructions would be greatly appreciated- pictures would make it even better!
I did a search- seems there is a circlip thingy that has to be removed somewhere?
Thanks in advance,
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 08-24-2007, 09:44 PM
- Self Moderating -
Try this..
http://www.pelicanparts.com/techarticles/911_930S_wheel/911_930S_wheel.htm
Tim
Present: 57 Intermeccanica Speedster Ivory on Brown
Past: 85 911 Carrera Coupe Silver on Black, 57 Intermeccanica Speedster White on Tan
Old 08-24-2007, 09:52 PM
Paul K's Avatar
Thanks Tim- so am I correct in thinking the hub goes on first, connect the horn wires, then the wheel goes onto the hub, and I'm done? Does the horn pad on the 930s pull off like the original?
Thanks,
Paul.
'83 SC Coupe SOLD
Old 08-24-2007, 10:01 PM
Cooper911SC's Avatar
Yup you are correct...first hub then wheel...although on my SC the wheel and hub just stay together and when I undo the 27mm? nut I can just wiggle it all off. (After unpluging horn wires)
Yes the horn pad pulls off of the wheel...it takes a firm pull.
Not sure about a circlip...there is a wavey lock washer between the hub and nut on my car though.
Good luck with your upgrade...I just recently switched back to a stock SC three spoker...the 930 wheel was looking a little beat.
Cheers, Coop
Cooper's Classy Car Care
Providing Clear Bra installation, Paint touch-up, Detailing
PCA/OCR since 1997
'81 911SC, '95 993 Tip. Project 'Euro spec' '70 914-4 w/2.0 & side shifter
Old 08-24-2007, 10:16 PM
Paul K's Avatar
Thanks Coop- do you know where the two wires go? I only see one in the picture of the original wheel and two on the 930s. Guess I'll figure it out!
Cheers,
Paul.
'83 SC Coupe SOLD
Old 08-24-2007, 10:22 PM
Driving member
jester911's Avatar
You will probably need to reuse the turn signal canceling ring from the back of your existing wheel.
Jerry
'86 coupe gone but not forgotten
Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason.
Old 08-25-2007, 03:51 AM
Paul K's Avatar
Jerry:
The new hub has a tab on the back which (I think) is the turn signal release. I'm going to try the install today- so watch this space for either before & after pictures or a bunch more questions!
Thanks,
Paul.
'83 SC Coupe SOLD
Old 08-25-2007, 07:37 AM
Paul K's Avatar
Update:
I can confirm that a 27mm impact socket WILL NOT FIT in the hole in the original wheel. Off to the auto parts store to buy a regular 27mm socket...
'83 SC Coupe SOLD
Old 08-25-2007, 11:20 AM
Make Bruins Great Again
Por_sha911's Avatar
Make sure your wheel is dead centered and the front wheels are straight before you take the old wheel off. This will make lining up the new wheel a lot easier.
Joe
Old 08-25-2007, 11:56 AM
Paul K's Avatar
Done!
Before:
After:
'83 SC Coupe SOLD
Old 08-25-2007, 01:23 PM
Looks great!
Nice upgrade.
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 08-25-2007, 01:35 PM
Paul K's Avatar
Thanks Mark! It was way easier than I had expected- and I think it really freshened up the interior. Next job- fix/replace that worn shifter knob!
'83 SC Coupe SOLD
Old 08-25-2007, 02:48 PM
Hey Paul- Looks great! Glad you figured it all out.
As for your shifter, you can try having it re-dyed. Also our host or AGLA sell a kit that allows you to replace the leather...not sure if white will be available...might be worth looking into having an interior repair guy just clean yours up and re-dye it.
(I work in automotive exterior re-conditioning and constantly come into contact with interior repair guys. You're probably looking at less than $100 to have the shift boot taken care of.)
Cheers, Cooper
PCA/OCR since 1997
Old 08-26-2007, 07:09 PM
Paul K's Avatar
Cooper:
I just bought a new one on Ebay. Looks a lot better than mine- I'll either use it as-is, touch it up with some dye or turn it black and sell it...
930s install was a breeze. Hope the other jobs are this easy!
Cheers,
Paul.
'83 SC Coupe SOLD
Old 08-26-2007, 08:06 PM
