rw7810's Avatar
Rear Wheel Bearing Question
How noisy should rear wheel bearings be with axle and brakes disconnected?? Trying to decide if they need to be replaced. Both sides make some noise, with the left side with a little more growl.
Robert Williams
70' 911T
Old 08-12-2007, 10:18 AM
sudo apt-get purge 930
equality72521's Avatar
My bearings make no noise at all that I can tell.
--clutch-monkey
Old 08-12-2007, 04:33 PM
Evolved
Mo_Gearhead's Avatar
Brakes disconnected: Does that assume the parking brakes also? Could they be slightly dragging?
Don't fear the reaper.
Old 08-12-2007, 04:42 PM
No Band
futuresoptions's Avatar
Bearings are cheap and often overlooked... change them out while you got everything apart....
"HEY A$$MAN!!!"
Old 08-12-2007, 04:55 PM
Bearings should be changed on a regular basis. I do my front ones once a year as i run sticker r compound tyres. I havent had a failure. The rears have been done every 3 years. However the rear on the race car that runs slicks is done yearly.
Michael
Old 08-12-2007, 05:10 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
No Noise. If they are growling...change them. If you are even questioning "how bad do they have to be"...change them. The consequesnces are just not worth it.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 08-12-2007, 07:52 PM
