mca mca is offline
mca's Avatar
Clutch Shudder - Proper Torque for Engine-Tranny Nuts?
Anyone know the proper torque for the tranny to engine nuts?
Anyone know the proper torque for the tranny mounts and engine mounts?
Afer I lifted the rear via the sump plate, I noticed some clutch shudder.
It isn't terrible and I can avoid it by riding the clutch a little, but it is certainly noticeable to the point of needing to be addressed.
I am hoping for the best (that it isn't a tranny leak) and figured that I would run through the tranny to engine nuts and tighten them to the proper torque settings.
Many thanks,
Craig
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Old 07-22-2007, 05:19 PM
Make Bruins Great Again
Por_sha911's Avatar
Per Bentley's 1984-1989:
Crossmember to Crossmember Mounts: 58 ft/lbs
Trans to Engine: 33 ft/lbs
Maybe someone has the spec for 1982
Joe
Old 07-22-2007, 06:20 PM
Grappler
Rodsrsr's Avatar
Check your clutch cable adjustment.
Old 07-22-2007, 10:07 PM
mca mca is offline
mca's Avatar
Thanks ... I need to get the Bentley.
Will also check clutch cable.
Old 07-23-2007, 06:30 AM
