the911Tprocess's Avatar
1972 T chain ramp question
Can the chain ramps on a 1972 T 2.4 with MFI be replaced dropping the engine?
_____________________
Mark
911 T 1972 Black almost done!
Old 07-20-2007, 12:35 PM
sorry ,what I mean is can the chain ramps be replaced without dropping the engine.
Mark
Old 07-20-2007, 12:37 PM
Kantry Member
oldE's Avatar
Yep!
You will have to remove the engine mount to get the shouldered bolts out of one side (left?) and you will have removed the engine tin from the rear. Be very very careful with the ramps which fit into the case near the center. Some people have lost these into the case. Not me, but some people.
Les
Best
Les
Old 07-20-2007, 01:29 PM
Early_S_Man's Avatar
Porsche Crest
Yes.
1. Remove muffler.
2. Remove two rear-most pieces of engine sheetmetal.
3. Support engine at normal ride height with small/short jack stand or bottle jack.
4. Remove engine mount crossmember.
5. Remove rear 'console' or engine mount.
6. Now you have access to remove chain covers, and can remove/replace chain ramps! Needle-nose Vise-grips are your best friend ... grab each ramp [inner four] before removing the two retaining bolts.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-20-2007, 02:15 PM
chain ramp removal
thanks guys,
will work on removing chain ramps this weekend.
Advice always appreciated!
Mark
Old 07-23-2007, 05:44 PM
