dan79brooklyn's Avatar
Yes..mine is noisy and slow but it works if you're patient...Used it to test the spare and one other time at the track to add a few lbs. of pressure.
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon
(new addition 1998 Mazda Roadster)
EX - 1993 Porsche 911 Carrera 2
EX - 1979 Porsche 911SC TARGA
EX - 1976 BMW 2002
Old 07-24-2007, 02:42 PM
Early_S_Man's Avatar
Porsche Crest
Dan,
You could try disassembling the plastic housing and clean the cylinder & piston out with Brakleen while tuning over by hand until the solvent doesn't come out black. Then, let it dry out for an hour or so, turning over a couple of times by hand while it is drying. Apply some engine oil to rod bushing and cylinder, turn over by hand until thoroughly distributed, then hook up power and try the pump. If not completely worn out ... it should be a lot quieter with fresh, clean lubricant!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-24-2007, 03:20 PM
