-   -   Please tell me what this part does???????? (http://forums.pelicanparts.com/porsche-911-technical-forum/358627-please-tell-me-what-part-does.html)
mhinch 07-23-2007 03:09 PM
Carrera 3.2 1986 Euro spec. UK reg. car
I'm thinking the part is a vacuum hose for the power brakes, I've been stripping the inlet manifolds off to replace the gaskets (3 out of 6 had "sucked in" ) and I noticed the rubber connector on his pipe had perished. Obviously I'll replace the pipe ($145 ouch), but I'd like to know its function, my Bentley manual doesn't seem to mention it.
http://www.pelicanparts.com/cgi-bin/smart/imgdsply.cgi?pn=93011032803-M100&html=Y
Thanks in advance
Mark
slodave 07-23-2007 03:29 PM
That's what I heard as well. Instead of paying for a new line, can you take it to a hydraulic shop and have them put a new hose on? I replaced mine, only to find out later, that a lot of guys have theirs repaired for a lot less.
Dave
mhinch 07-23-2007 03:52 PM
Thanks for the advice Dave, I'll take it to the local hose shop tomorrow. What I wondered was if it is a vacuum hose and is sucking in air, was this contributing to my engines rough idle? What symptoms did your spilt hose give?
Mark
Rot 911 07-23-2007 05:40 PM
Yes, vacuum line for your brakes. Mine was cracked and I wrapped it in some of that self-sealing rubber tape. Held up for 3 years now.
slodave 07-23-2007 05:55 PM
Mark
I can't say I had problems. It must have been cracked for a while, but I finally used some duct tape on it a few years ago and that worked until I took the engine out last year and replaced it.
Dave
mhinch 07-26-2007 12:07 AM
Got the hose repaired yesterday, job sorted
cheers guys
slodave 07-26-2007 12:11 AM
cheers guys
Cool and probably for less then buying new one! I did keep my old one and plan on getting it repaired one of these days.
Dave
john walker's workshop 07-26-2007 05:19 AM
a short piece of heat shrink tubing takes care of that real cheap.
rcorujo 04-15-2016 07:59 PM
Does the cracked hose can produce engine misfiring?
Wayne 962 04-16-2016 10:17 PM
It shouldn't. This is simply a conduit for vacuum. The reason why it's mostly metal is so that it doesn't collapse on itself. When I did the Super Boxster conversion for the Boxster book, I used standard "vacuum hose" that collapsed on itself. It still worked fine, but it certainly doesn't look like it should work as well. Power brakes work fine though. Still, this on the "replace eventually list..."
-Wayne
