-   -   2.7 Script - Where exactly does it go? (http://forums.pelicanparts.com/porsche-911-technical-forum/358712-2-7-script-where-exactly-does-go.html)
Downerman 07-24-2007 02:28 PM
Ok, I know it's on the right side of the grill about center I believe but then again I am not sure so......... does anyone know the exact location for the 2.7 script on the engine grill? For what it matters and I don't think it does it's a 74 Carrera.
mark 74 carrera 07-24-2007 04:13 PM
I will measure mine and get back to you.
Mark
AshEvan 07-24-2007 04:34 PM
Hope this helps
I also had the same question about a year ago and I think the bottom of the script plate needs to be on the 6th grill bar from the bottom, centered between the two vertical grill bars on the right . . . . did I confuse you already.
I was going to provide a pic but I can find the add photo feature on this new format.
mark 74 carrera 07-24-2007 07:02 PM
Mine is located between the 7th and 8th horizontal grill bar form the top. It is located horizontally 2.25 inches (that is the 7 in 2.7) is 2.25 inches from the outer most vertical cross member.
Hope this helps, Mark
