Headlight Wizards Help Needed
My headlights will not come on (both low and high beam) and the turns signal lights on the dash blink at a higher rate then fade completely. Other lights like hazards, reverse, breaks, interior, glove and gauges work just fine.
When the car is running and I pull on the headlight knob to turn on the headlights, the BLUE light indicating highlights on the gauge come on in both the high and low beam light position . . . .but no headlights.
* Checked and replaced healdight fuse.
* Starter switch is new.
Has my turn signal assembly falied and causing this?
Help needed as I am in the DARK.
M-74
Old 07-24-2007, 11:58 PM
It could be a relay, check that out.
Old 07-25-2007, 06:40 AM
MBruns for President
JeremyD's Avatar
mine did this and it turned out to be the headlight switch at the stalk /turn signal. Are you running higher than recommend wattage headlight bulbs?
Old 07-25-2007, 07:23 AM
Jeremy-Does this mean I need to replace the switch
Jeremy.
Glad to have someone iwht similar experince. I believe headlights are stock, so does this mean I need to replace the trun signal assembly?
M-74
Old 07-25-2007, 10:49 AM
Please elaborate regarding relay.
Thanks,
M-74
Old 07-25-2007, 10:50 AM
The Unsettler
stomachmonkey's Avatar
Replace the Turn signal switch. Happened to me twice. 1st time flying down an unlit country twisty in the dark. Not a time to go blind.
Install relays even if headlights are stock.
Common known problem.
"I want my two dollars"
"Brandon Won"
Old 07-25-2007, 11:24 AM
The Unsettler
Link to relay kit thread
Headlight relay kits
"Brandon Won"
Old 07-25-2007, 11:26 AM
