Johnb911's Avatar
Should I lower and how much
I have a 70SC ROW with 17" Cup wheels.
No car hear so I don't know the size of tire.
I would like to by the Moses Fuchs this winter.
Heres the real question:
Does it look like I can go lower.
What do i need to do or I guess what do I need to buy to do it right?
JOHN
79 EURO SC
"24 Years Later - The Dream Came True"
Old 07-20-2007, 03:34 PM
You can go lower. How low you go is going to be determined by what torsion bars you are running and what your camber is set at etc.
My car is lowered to much for most peoples taste but I like it. If my car was not set up for the track then I would have had to have been more conservative while lowering my car.
There are quite a few threads on lowering on this board but make sure to plan on a corner balance and alignment when you are done lowering your car.
Hope this helps,
Shawn
Old 07-20-2007, 03:49 PM
1) read as much about ride heights and lowering in the threads you search here.
2) measure your current ride height at each wheel on a level ground. write it down.
3) decide whether you need to rebuild (revalve) or replace the shocks.
4) decide whether you need/want to go with bigger torsion bars.
5) decide whether you want to put in new a-arm bushings. search for how to check whether you need new bushings or not.
6) PLAN on new spring plate bushings. Decide whether you want ER polybronze, polygraphite or neatrix.
7) plan on a bump steer spacer kit for the steering rack if you lower the car.
Lowering below Euro spec for the street could give you some handling issues. (steering and shock travel)
lowering the rear is going to be the biggest job for a first timer, but very doable. research the archive. Plan on not driving the car for a couple weeks while you work on it.
Take lots of notes and/or photos as you go for reference. Once everything is back together you WILL need a 4 wheel alignment and corner balance. Budget for that.
Tony G
2000 Boxster S
Old 07-20-2007, 05:34 PM
Yes, you should lower your car.
A rule of thumb is .5" higher on front. I'd say around 25" from ground to fender lip is the easy way to go.
Old 07-20-2007, 06:52 PM
Banned
Lower it until the gap between the tire and fender lip is gone.
Old 07-20-2007, 08:11 PM
Danny_Ocean's Avatar
And then go another 1/2"...
Old 07-20-2007, 10:06 PM
MIK911's Avatar
Danny/Dipso---Good answers
Mike
'86 911 coupe
'85 BMW 535i
'11 Cayenne
Old 07-20-2007, 11:30 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Danny - quick question, what fasteners did you use to attach the arches on your car. Do you have details and more pics?
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 07-21-2007, 02:38 AM
Low is good. Considerations need to be made for Torsion bar size, tire size, tire profile, camber and toe settings.
Old 07-21-2007, 06:21 AM
I didn't do the bodywork. It appears the fastener is a flat large-headed slotted stainless bolt with chamfered edges. I don't have close-up pics, but they appear proprietary to the kit...they don't look like something bought off the shelf.
Old 07-21-2007, 07:43 AM
coolcavaracing.com
Kroggers's Avatar
Wold you mind sending me an email/PM with some close up pics?
Old 07-22-2007, 07:46 AM
Sure. It might be a few days before I get to my shop where the car is garaged. If you don't receive pics by Wed., send me a reminder.
D.O.
Old 07-22-2007, 10:16 AM
coolcavaracing.com
Kroggers's Avatar
Cool, you can send them to: Paul(at)coolcavaracing(dot)com
Old 07-22-2007, 11:29 AM
Johnb911's Avatar
Hey, thanks for all the input.
JOHN
79 EURO SC
Old 07-23-2007, 09:03 AM
Very nice looking car. Lowering will bring the look to fruition but beware, the rear is a PITA. Don't ask me how I know.
87 blk coupe
Old 07-23-2007, 04:17 PM
Personally, I think the car looks good and wouldn't lower it. Can you post the numbers....ground to fender through wheel center. I am in the process of getting mine setup and would like a good reference. If you just wanted to, I would think a .25" drop all around would be as much as you should go but would still need an aligment afterwords.
Old 07-23-2007, 08:48 PM
Johnb911's Avatar
I'll try to get to the garage tonight and messure it.
JOHN
79 EURO SC
Old 07-24-2007, 04:23 PM
Johnb911's Avatar
74er,
The front is 25.25" and Rear is 25"
JOHN
79 EURO SC
Old 07-25-2007, 01:19 PM
19 years and 17k posts...
azasadny's Avatar
Beautiful "middie"!
Beautiful "middie"!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-25-2007, 01:24 PM
