964 Wet Feet
My 1992, 964 dumps water on my feet. Actually it does it on both the drivers and passengers sides. seems to happen really bad on cornering. It is obviously from the AC condensation drain not working properly. It does work because there is water on the ground under the car but on hot humid days when the AC is working its butt off, 8 or 9 months out of the year around here, My feet get soaked.
Is there a better or best way to clear this drain line or insure all is working as it should?
Thanks,
Kevin
Kevin
'79 Coupe
Old 07-27-2007, 05:14 AM
You might try insulating the line with foam tape. Condensation forms on humid days along the lines which should be insulated.
Old 07-27-2007, 11:08 AM
