kentSC's Avatar
Lightbulb Rough idle, stalling, goes above 3500 RPM
I'm having trouble with my 81 SC. The engine has a very rough idle when cold, and stalls when warm. When the revs get above 3500RPM it goes very well. I did a lot of tidy up work to the engine about six months ago and it has only started playing up in the last month or so. I replaced the plugs, leads, and a heap of other stuff when I had the engine out, and it use to run great until recently. Any clues? I have a photo of the engine before and after the restoration.
Old 07-22-2007, 05:06 AM
kentSC's Avatar
Unhappy
Any help on this would appreciated.
Kent
Old 07-28-2007, 12:53 AM
Designer King
Paulporsche's Avatar
Engine looks nice. Check your control pressures. Could be the WUR.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-28-2007, 09:49 AM
OZCarrera3's Avatar
I see a "Jurgen" in your future!
Just kidding Kent. At least when we find out what's wrong with my CIS, we can resolve yours a lot more quickly and cheaply!
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 07-28-2007, 05:23 PM
kentSC's Avatar
Paul,
Thanks for your reply. Your car sounds like she would be a nice ride. I wondered about the WUR myself as the wires seem a bit loose where they connect. I also read elsewhere that the vacuum lines may need checking.
Sheldon,
You're a funny man . I'll have a go at checking a few things next weekend, and try to get the fan shroud to sit properly. If none of these work, then yes, I think a visit to the Jurgen is likely.
Kent
Old 07-29-2007, 12:39 AM
