Can we talk door handles..........
Ok so the drilled ones on left,are what came with car.(ugh) Obviously they have the correct barrels and tumbler for the key,I want to use.
The handles I want to use are the early 912 68/69ish ones on right(I need one more)
I presumed that the barrels /tumblers would be interchangeable.Obviously they are not.
Option is to find another handle to make up my pair.Firstly, anyone know as to whether they are sided?
im sure they are not, even though they have different part numbers.
I will then send original key and barrels to a locksmith, who should be able to cut new key, or move tumbler/pins and make my original key fit.
Comments/Advice always appreciated
Old 12-25-2020, 01:39 AM
Flojo's Avatar
I have light patinated set of SWB/912 handels with locks and all. Even a key. It is broken, but OK to make a copy from a Pro.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 12-25-2020, 04:26 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
'69 was the one-sided small Volkswagen style key. '70 started the larger 2-sided key with the plastic head. It makes sense that the lock cylinders would be different, though I had never given it much thought.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 12-25-2020, 01:52 PM
Been here a while
And let’s keep in mind, the ‘69 and earlier cars had a separate key for ignition versus door locks. So, if you are backdating the door handles, you’ll be in the same situation.
looking for 1972 911t motor XR584, S/N 6121622
Old 12-25-2020, 04:35 PM
Thats what I need but only one! Condition is too good.I will be replating.Are the handles sided or both identical.Thats what I need to know?
Old 12-26-2020, 12:04 AM
That makes lie easier.I prefer seperate keys anyway.
Old 12-26-2020, 12:05 AM
Been here a while
Some bits here. https://www.early911sregistry.org/forums/showthread.php?156572-1968-1969-Door-handles-and-lock-parts
Old 12-26-2020, 03:30 AM
