Inside Mirror
Any suggestions on making it easier to insert the inside rear view mirror into the mounting bracket? It is so tight a fit as to make it extremely difficult to press all the way home.
Thanks! |
I have two mounting brackets in my car, which has a roll bar--one down low so on the highway I can see under the roll bar, one up high for the track, so the view out the windshield isn't obstructed. I switch the mirror back and forth between the two and use a small plastic-head hammer--tapping gently, gently--to get the mirror in and out of its bracket. And I never seat it so far home that it'll be impossible to remove.
| All times are GMT -8. The time now is 10:19 PM. |
