-   -   Sc A/c........ (http://forums.pelicanparts.com/porsche-911-technical-forum/359580-sc-c.html)
fred cook 07-30-2007 10:29 AM
Sc A/c........
Which would be more bang for the buck to replace? The evaporator or the condensors? I have already replace the compressor with a Sanden unit, added a Pro Cooler and rebuilt the hoses with barrier hose. Now looking to go the next step.
Thanks,
scottb 07-30-2007 10:39 AM
Have you considered ADDING a condenser/fan assembly in the front left fender? That will give you the most improvement, and bang for the buck!
Barrpete 07-30-2007 11:41 AM
One of the big deficiencies in Porsche AC systems is lack of condenser capacity. So anything that improves condensor efficiency will help. You've already added a procooler, either adding another condensor or upgrading an existing one will help as well.
I would think the condenser would make more of a difference than the evaporator. It's also a little less work to remove/replace one of the condensers than the evaporator.
ljowdy 07-30-2007 12:17 PM
I used a griffiths additional condenser with a fan. It's mounted inside the back left fender
but, I also changed out the evaporator, hoses and compressor. Works gar better than any stock system for a 1973 model 911.
Hladun 07-30-2007 12:24 PM
Biggest bang...fan for the condenser! Do this before you get another condenser. Do a search.
