nameisbauer's Avatar
Send a message via AIM to nameisbauer
Keyhole in the door?
I tried to search, but I couldn't find anything.
I just found this keyhole in the side of my drivers door in an 1981 SC.
What is it for?
Jim
911 Mint Green "RSC" #mintgrun
911 Gentlemen's Rallye 85 Carrera GP White
2012 C63 AMG Mars Red
Old 07-29-2007, 07:11 PM
Ova Day
msterling's Avatar
Alarm system.
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 07-29-2007, 07:22 PM
sudo apt-get purge 930
equality72521's Avatar
+1
--clutch-monkey
Old 07-29-2007, 07:27 PM
What does it do for the alarm system?
Jim
Old 07-30-2007, 09:48 AM
You've located how to arm and disarm your alarm system. I believe when armed you can open the door app. 9" without the system going off. This gives you enough room to reactivate the alarm.
Old 07-30-2007, 11:46 AM
sorry 9" so you can deactive the alarm.
Goldfinger
Mattcamp's Avatar
arms and disarms the alarm......you'll be lucky to get the door open far enough to disarm it without it going off first. It uses a special key, not your ignition or door key.
1984-Carrera (pewter metallic)
Old 07-30-2007, 12:03 PM
Ha, thanks. I was going to try with my ignition key. With my luck I would be able to arm and not disarm.
Jim
Old 07-30-2007, 12:43 PM
you can increase the amount that the door opens before the alarm goes off, if you put a washer underneath the door switch. You have to hold the black plastic plunger while you unscrew the the threaded switch base, or the wire will come of and most likely be lost inside the door post.
Old 07-30-2007, 01:25 PM
