myrddin's Avatar
heater blower troubleshooting...
Working through a life long list of things that will forever bother me.... I have no heat... so today I decided to take a break to look for anything obvious.
1. I checked power at the plug with a 12 volt meter (I had the ignition on with the 2 red levers up between the seats) I have no power at the 2 prong femail plug where it goes to the motor.
now where do I look? I checked all the fuses all are not blown, I don't know where else to look.
I understand the heater blower is turned on when you lift the red levers but how do I see if there getting power?
Help... man I love the car but someone did some crappy work when they put the 3.2 in there.... the electrical work needs help....
Also I have the late model Porsche reflector (ghosted Porsche letters)... I took it off to take a look behind it (need to get some paint and start spraying under and inside things to eliminate rusty surfaces) and any how there are 2 lights on the back of the reflector not hooked up... any idea how I can hook them up?
never ending work... I think at some point you just got to drive them and forget about all the things you wish were new and up to date... it will drive me crazy till I give in.
Hope you guys can help????
looking...
Old 07-31-2007, 01:54 PM
myrddin's Avatar
Might have found the problem?
heater blower relay on 84 carrera
See my pic below ( I have no engine compartment fuse box or plate) I have no relays.. Can anyone help me get one put in?
Also the last few you will see a gray box with a lot of wire ran to it.. there are 2 spots open and there are 2 loose wires back there?? you think they go there?
PIC:
looking...
Old 07-31-2007, 02:36 PM
I have a 1980SC. Hopefully they are similar, if not the same. First, turn the ignition on but don't crank the engine. Open the hood and you would most likely be able to hear the heater motor running. Assuming you don't hear it. Check if there is power at the switch, not the levers between the seats. The levers between the seats are just vent levers. Speaking of which, lift up the levers. Check under the car and see if the vents are actually opening when these levers are up. Then check to make sure they are closed when the levers are down. A lot of times the springs are missing or get bound and can no longer function. Hope this helped. If not, I tried.
Old 07-31-2007, 02:39 PM
myrddin's Avatar
thats is my problem, I have no power to the heater blower motor... You think its because Of my post above? Should the blower motor run all the time?
Man, I wish I would stop looking for broken stuff. I hat it when I find something that is not right....
Thank you for your help... Hope [I hope I can figure it out??
looking...
Old 07-31-2007, 02:46 PM
aj88cab's Avatar
You have quite a mess there my friend. There are several components missing that are part of the fuse/relay panel missing from your car. Without them the blower fan will not work. In addition to the thread you found above read thru these (including the detailed links in the second post): Heater Control Circuit
Once you understand the circuit you will know what you need to get. On the other hand you could just backdate the heater plumbing and the engine cooling fan will probably give you enough heat most days as long as your heater valves are properly functioning when you pull the red levers.
Edit - I just noticed you have an '82 with a 3.2, so the above threads may be more confusing than helpful, they are for '84-'89 Carrera's...oops. So depending on how extensive the 3.2 transplant was it may be of no help at all. Did the transplant include/exclude other components and/or wiring harnesses?
Good luck
Andrew
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 07-31-2007, 03:05 PM
Born to Lose, Live to Win
ramonesfreak's Avatar
i have an 83...but my wiring is stock. i cant tell whats going on with your wires. in my car, there is a small fuse box on the left side of the engine compartment where the heater blower fuses are located. mine recently blew and i had a small fire in my blower motor so ive disconnected the blower motor for now
i believe the floor levers not only open the vents, but also activate the blower motor. i found with my heat recently, even though i dont currently have a blower motor, im still getting heat when i pull up...just no motor actually blowing air through the heat exchangers.....so, the heat just doesnt come out as powerfully as it did...but i still get some...so long as i am moving
i know that my blower motor only turned on when i pulled up on the levers. where your fuses are, im not quite sure now since you have a later model engine and blower motor and a giant soup of wires
what i also dont understand is why you dont have heat...unless you have not tried while your moving. next time its cool, go for a drive and pull up and see if heat comes out, regardless of whether or not your blower motor operates. i believe you should. you still have heat exchangers?
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 07-31-2007, 03:17 PM
Wash. State
nesslar's Avatar
Smile
Wow! I would cut that whole snag out of there, put it in a can, and go fishin'! Seriously, though, I'm betting you'll get the help you need from these folks around here!
Old 07-31-2007, 03:21 PM
myrddin's Avatar
wouldn't you think I need the fuse tray posted in my link above? There really isn't more than a hand full of wires and 2 plugs (its just about a foot long and all balled up. I take it some wires go to a small fuse box and some go to a few relays... I have a cab so the rear window defogger would not matter to me.. just need the heater blower to operate. I guess I need to get out the meeter and find every wire there and write them down with color code.... then I Will need to find out what is hot and what is a ground... after that the ones that are not a ground should be the other half of a circuit I guess.... somewhere I should be able to find a circuit for the back fuse panel right.
man head is hurting already....
need that fuse tray thing, any ideas?
looking...
Old 07-31-2007, 04:00 PM
myrddin's Avatar
man... I am going to need some help on this one... anyone have an idea? what all am I missing with this being gone? I looked for a min and it had things like back up lights and blower motor and rear window defroster as well as flasher and other things... All that stuff works? Well I dont have a rear windo to defrost... but back up lights and flashers and such work fine? I guess they could have rewierd some things? looking now to figure it out... Wonder if I can jump something to get the fan moving? is it a positive negitive plug?
looking...
Old 07-31-2007, 04:21 PM
myrddin's Avatar
OK so far I know for sure I have no Reverse lights and no power to the heater blower motor.... Also the licens plate lights and the engine compartment light....
Can anyone help me fix this... how the heck did the PPI mis reverse lights?
Need the missing parts and a electric master to help...
looking...
Old 07-31-2007, 05:37 PM
Used Up User
imcarthur's Avatar
Yeah, you're nowhere close to a heater relay discussion.
Go to http://www.pelicanparts.com/PartsLookup/HTML/911_USA_84_86_KATALOG/902-00-Frame3.htm
You are missing parts 14 - 30. The fuse/relay panel etc. Since you have a 3.2 engine this is an '84 diagram.
Ian
'87 Carrera Cab
myrddin's Avatar
So I need parts 14 - 30.... man... ok well I guess I will start hitting up parts cars... Anyone have these parts?
looking...
Old 07-31-2007, 06:05 PM
