-   -   Wiring diagram needed - '81 14 pin connector on relay side (http://forums.pelicanparts.com/porsche-911-technical-forum/360088-wiring-diagram-needed-81-14-pin-connector-relay-side.html)
PcarPhil 08-02-2007 04:31 AM
Hey there folks -
I'm wondering if anyone here can provide me with the wiring diagram for the 14 pin connector that's located on the relay panel in the engine compartment of a 1981 911SC.
I'll be installing an '85 3.2 and I need to figure out if I have to change any of the pinouts.
Thanks for the help!
PcarPhil 08-02-2007 11:39 AM
I think the info below should work for a bare bones 3.2 install into an '81 chassis:
http://forums.pelicanparts.com/uploa...1186173450.jpg
Can any of the experts here confirm that on the '81 chassis harness side that pins 2,7,8,10,12,13 are not needed?
aftermath 08-02-2007 12:34 PM
kaefer do you have that diagram for a 930 turbo :)
PcarPhil 08-02-2007 12:44 PM
No I don't. I came up with the above diagrams by doing a 19 page search here on Pelican for "14 pin connector" and another search for "3.2 swap"
Brian 162 08-02-2007 06:10 PM
One half of my 14 pin connector broke when I took it apart last week. Do the wires match from the male end to the female end of the connector?
Would the above info be the same for an 80 SC?
Brian
PcarPhil 08-03-2007 03:45 AM
Brian
I believe the info above is the same for all SC's - though I may be wrong.
Also, I received a PM last night about my chart. There may be a discrepancy with the #7 wire. Instead of Blue/White it should be Blue/Yellow.
I'll check on this and change the chart as necessary.
Thanks.
PcarPhil 08-03-2007 10:57 AM
I checked on my '81 and #7 on the chassis side is indeed Blue/Yellow. I'll updated my chart asap.
Brian 162 08-03-2007 02:38 PM
boyt911sc 08-03-2007 06:44 PM
14-Pin Connector
Scott,
I'm not an expert in CIS but I do have some answers to your inquiry regarding the following pins:
These are on the engine side of the 14-pin connector.
Pin #2, #7 & #8 - wires going to the engine side unused/blanks.
Pin #10 - (red/white) power to WUR, AAR, & TV.
Pin #12 - (black/purple) is signal wire for tachometer from CDI @TD.
Pin #13 - (yellow/black) power to heater blower.
Pin #10 & #12 are mandatory. You cannot run the engine without these wires connected. Pin #13 is optional. Lastly, the information given on the table you attached have several inconsistencies because of the mixed up in chassis side and engine side terminals.
PcarPhil 01-09-2008 04:22 AM
Originally Posted by boyt911sc (Post 3410209)
Scott,
boyt911sc,
I just came back to this thread to print off my chart for my own use and came across your post. I agree that pin 10 and 12 are used for CIS but my chart was created for installing a 3.2 (non-CIS) into a SC chassis.
On a 3.2 the tach signal wire is in the DME harness and there are of course no WUR and AAV on a 3.2.
Please advise if I'm missing something. Thanks!
MBEngineering 01-09-2008 06:52 AM
HI Kaefer
Sorry to hijack the thread,
"aftermath" which part of the 930 (year) diagram do you need??? PM me.
"kaefer do you have that diagram for a 930 turbo "
regards mike
PcarPhil 01-09-2008 08:50 AM
Mike - no problem.
I have another question - is pin 14 (red B+) actually needed for a very simple wiring setup?
I don't think it is. I've been working on wiring recently and I think pin 14 is only used to provide power to the rear fuse panel and relays. If I'm not running a heater blower motor, rear defrost, etc. can I remove pin 14 from the 14 pin chassis harness?
safe 01-09-2008 10:48 AM
Boy, the timing on this thread was spot on!
Just been analyzing a 3.2 harness checking it against wiring diagrams in the Haynes manual to see what I can use for my efi project.
PcarPhil 01-09-2008 11:30 AM
Originally Posted by Kaefer (Post 3693067)
Mike - no problem.
I decided to post a new thread for this question:
http://forums.pelicanparts.com/porsche-911-technical-forum/386453-pin-14-red-b-needed-chassis-wiring-harness.html#post3693491
