Jeff Alton's Avatar
Ever wonder what goes into making a three piece wheel?
Some have expressed interest in seeing what goes into the making of an aftermarket 2 or 3 piece wheel with a "forged" center. This thread will show the materials as they show up at the manufacturer and then show the machines used to create the wheel. I will show as many of the steps as possible, but still need to take a few more pics.
So for now, here is the materials as they arrive......
Forged blanks, notice the different profiles available. A manufacturer can choose from many readily available shapes/sizes/profiles or can spec out their own custom one. (By the way, most if not all the manufactures in the US get their forgings from the same company.)
Here are a couple of slightly different forgings.
Here is the sheet aluminum that arrives ready for cutting to make the cirular blank that eventually becomes a wheel shell (inner or outer). This is 6061, but some use less expensive 5000 seires (the actual number escapes me).
Next up we will start with the making of a wheel shell. I will post the machines and processes used to cut/form/heat treat/machine/polish a wheel shell.
Stay tuned.
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 08-03-2007, 09:46 PM
Senior Member
More!
2010 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 2010 Jaguar XF (fast touring car), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 08-04-2007, 07:01 AM
Jeff Alton's Avatar
Okay, the sheet aluminum gets cut into circles of specific size depending on the width/diameter of the wheel half that is being made. A CNC router with a vacuum table is used to nest the parts. There needs to be waste material so that the machine hold its vacuum. All waste sheet gets recycled by the shop's local metal recycling outfit. Just load it into the bin, when it is full, they come and get it.....
Here is a CNC router typical of what most wheel makers would use.......
Next up I will show the spin forming machine and the dies used to make wheel halfs. I will also show some parts before and after forming.
Cheers
Old 08-04-2007, 09:36 PM
Subscribed
Old 08-05-2007, 12:11 AM
I'll race for food
gostraight's Avatar
sub'd
Radu
'82 SC black on black "The Beauty"
3.8 RSR GT2 track/street "The Beast"
www.octanegallery.com
Old 08-05-2007, 02:18 AM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
want to see more please!
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 08-05-2007, 02:22 AM
12 years and 17k posts...
azasadny's Avatar
Very cool! Thanks!
Art Zasadny
2010 MazdaSpeed3 (daily driver)
www.ford.com
Old 08-05-2007, 03:48 AM
Non Compos Mentis
I had the opportunity to tour the Fikse manufacturing facility a couple years ago. Absolutely fascinating.
Jeff, I'm looking forward to more!
Old 08-05-2007, 07:02 AM
Thanks for posting Jeff.
Old 08-05-2007, 08:11 AM
definitely subscribed
Grady aka plain fan
66 912 - enjoying the good life
78 911 SC and 90 C2 turbo look cab - gone but not forgotten
01 996 TT - daily driver and
09 Audi A4 Avant
Old 08-05-2007, 09:32 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
sub'd
1980 911SC #99 track car, 993 3.6, 50 PMO's
2001 BMW 330Ci Vert DD
2016 Ford F150 Supercrew
2016 MB E350 Sport wifey DD
2014 Unmarked Explorer "company car"
Old 08-05-2007, 12:17 PM
yay-yuh
Carl F
2000 Ruby Red Dodge Stratus with high performance racing stripe SE edition WTF? (sadly gone, but not forgotten)
1997 HOnda Accord "Shaggin Wagon"
1987 All black Targa
1998 Lemond Zurich/Dura Ace
2005 Jamis Dakar Sport
2006 Lemond Reno
2 DOgs , 2 Cats, Shi@ton of fleas
1 Cool as Hell Wife that tolerates my stupidity
Old 08-05-2007, 02:27 PM
Jeff Alton's Avatar
Okay, so each wheel shell "blank" (for lack of a better term) needs to be cut to a very specific dimension depending on the diameter and width required for the part. You can nest different size parts from the same sheet of material if you like, or you can make all one size at a time.
When the router has done it's work, here is what you have....
and some more.....
Now, you have to match the correct blank up with the correct selection of dies to make shape the wheel half. As you can see there is a lot of different dies one must have to make a variety of different inners and outers of various widths and diameters. They can be stacked together on the machine to get the correct width required. Here is a small sampling of the some dies one may use....
Next you mount the required dies onto a machine like this (spin forming machine) and let it do its magic.
It takes on of those blanks and forms you one of these (with out the center ID being trimmed or the bolt pattern in it)
Neither the router or the spin forming machine work magic on their own. They need to be programmed and tested and proofed to ensure the parts meet the specs. Once that is done and the program is proven, you could make a rough inner or outer shell in about 1 min.
Once the part is formed it is ready for heat treating. When the heat treating is done, it gets run throught the forming process one more time.
Next I will show some pictures of the Mori mill used to cut the inner bore and bolt pattern into the shell.
Then it will be time to make a center and head to the polishing room with our rim shells!
Cheers
Old 08-06-2007, 07:08 PM
alpina's Avatar
very cool
Chuck
04" Mini Cooper
66" sprite (scca "DP")
73" 914 2.2 (sold)
72" 914 1.7 (sold)
79" Alpina B6 (sold)
Old 08-07-2007, 01:08 PM
Thank you for taking the time. Fascinating!
87 blk coupe
Old 08-07-2007, 02:29 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Dont stop now.....
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 08-07-2007, 05:12 PM
Jeff Alton's Avatar
Taking one step backwards.....
I forgot to show a wheel half in the Mori being cut.f Here is one that has the bolt circle in it already, but is now going to have the bore ID trimmed. The probe you see stick out is meauring the part....
Cheers
Old 08-07-2007, 07:48 PM
Jeff Alton's Avatar
Here is what the forging looks like being loaded into machine. For its first pass, it is measured and then a hole is milled dead center. That is the first step.
Here is what it looks like being loaded on the "tombstone" before it makes its way around in the machine.
Next a front side pattern is machined (the face of the wheel), and then the backside is done. The backside varies quiet a bit as that is how one can accomodate a wide range of offsets down to the mm with the need for any spacers etc....
Unless you are ordering a "stocked common item" the backside program has to be created special for your wheels. This is what makes a "custom wheel" truely a custom wheel.
The machine can do magic if you tell it to, this model can hold 120 different cutting bits at any given time.
Tomorrow I will get some pics of a forging with the front side done and some that are complete. Then we can talk about finishing options.....
Cheers
Old 08-07-2007, 07:55 PM
The Chef
Guest
Posts: n/a
subcribed!
Old 08-07-2007, 08:07 PM
Jeff Alton's Avatar
Still jumping around a little, but here is the side by side pics of the steps in making a wheel shell, in this case an 17x1.5 outer.
The pics are the parts sitting on a sheet of 6061 that is on the router table about to be cut....
Step 1, this is how the part looks right after it is cut by the router.
Step 2, it is formed into this, then sent for heat treating.
Step 3 is heat treating, and step 4 is re spinning after heat treating. The part looks the same as it did in step 2 however.
Step 5, first polish.
Step 6, cut center bore and bolt pattern (1 machining operation) I showed this part in the machine a couple of post ago.
Step 7 is a final polish and then the part is ready for assemble to a wheel.
Cheers
Old 08-09-2007, 07:22 PM
