Garrison's Avatar
Car won't start...
I have been removing an old car alarm that was in the car and without really thinking I started cutting wires that were only connected to the brain of the alarm.
Now the car will not turn over at all. I am certain that it is something with electrical, and the starter. My thoughts are that I have removed the power from the battery to the starter, or from the ignition to turn over the starter.
Where should I start looking as I am at a loss to be honest.
Thanks for the help.
1996 Porsche 911
2013 BMW 335xi - Wifes car
2007 4Runner - 4x4 for Colorado snow
Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe
Old 08-11-2007, 11:31 AM
19 years and 17k posts...
azasadny's Avatar
Garrison,
I feel your pain! I had an old Hofco burglar alarm that was causing an intermittent no start condition and I finally gave up and took it to my buddy's shop (Tab Tanner at Autobahn Garage in Findlay, OH) and he removed it. I'm severely color-blind, so the wiring schematics didn't do me much good... My alarm was connected to the ignition and fuel pump circuits... Good luck!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-11-2007, 11:37 AM
Garrison's Avatar
Thanks... I am figuring that is going to be my best bet... because electrical is not something that I like to mess with at all....
Should have left it alone, but I wanted a cleaner engine bay...
1996 Porsche 911
Old 08-11-2007, 01:50 PM
Old Member
I would start by following the path of the yellow wire coming out of the ignition switch. I think it ends up at the solenoid.
Make sure the electrical plugs above the ignition switch and behind the dash did not come out during your alarm surgery.
Clifton Brown
https://www.mancalamarketing.com
Old 08-11-2007, 07:38 PM
Garrison's Avatar
I think the yellow wire has been cut...and this is where I am going to begin with the fix. Just hard to do when you have an active 2 year that loves the "Porsha"...
1996 Porsche 911
Old 08-12-2007, 05:33 PM
I agree with Cliff. I bet the yellow wire goes into and comes out of the alarm box. That is the starter solenoid signal wire from the ign. switch. If you're fortunate, you still might have the original Hofco wiring diagram somewhere. Your fuel pump activation circuit might also be affected.
Sherwood
Old 08-12-2007, 08:31 PM
