gtc gtc is offline
abides.
gtc's Avatar
8 Door Hinge Bushings?
Question: Where do all 8 door hinge bushings go?
After I determined that I needed to replace mine (actually, I didn't even see any in my hinges) I looked them up in the Pelican Parts catalog and found them under p/n 901-531-311-20-OEM. It said "8 per car," so I bought eight.
But all of the parts diagrams I have seen show only one bushing in each hinge. So where do the rest go?
Graham
1984 Carrera Targa
Old 08-06-2007, 09:46 PM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-06-2007, 10:46 PM
gtc gtc is offline
abides.
gtc's Avatar
One goes on top also?
You've given me a good idea for future threads: rebus tech questions!
Graham
1984 Carrera Targa
Old 08-06-2007, 10:55 PM
i've never done the job so i'd rather not comment. There's always nice comments around from guys who have btdt.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-06-2007, 11:14 PM
abit off center
cgarr's Avatar
Pull the pins and remove the door, they go in the hinge on the door top and bottom, then ream them out to 8mm
______________________
Craig
G2Performance
Old 08-07-2007, 05:02 AM
I would rather be driving
jpnovak's Avatar
Yep, as Craig Said. Also, you will be surprised how much a fully loaded door weighs. :O
btw, 2 doors x 2 hinges/door x 2 bushings/hinge = 8 bushings
Old 08-07-2007, 07:21 AM
Air Medal or two
afterburn 549's Avatar
I suggest unbolt it all (mark them b4so as to index) you will find that the pins will take some extreme effort to get them out. There is a special tool ... but a hammor and heat works for me.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 08-07-2007, 08:26 AM
gtc gtc is offline
abides.
gtc's Avatar
Originally Posted by cgarr View Post
Pull the pins and remove the door, they go in the hinge on the door top and bottom ...
Thanks guys, this is what I was looking for.
Graham
1984 Carrera Targa
Old 08-07-2007, 10:06 AM
