-   -   Starter 10mm Barrel Nut part number??? (http://forums.pelicanparts.com/porsche-911-technical-forum/360954-starter-10mm-barrel-nut-part-number.html)
Pkaaso 08-07-2007 08:35 PM
Anyone know the part number for the 10 mm allen/barrel nut the holds the starter on. This is an 84 application but I think they used it for many different years. (Yes I lost it).
Thanks in advance,
paul
2.7RACER 08-07-2007 10:08 PM
Hi Paul,
I believe it is the same as the cylinder head barrel nuts, 10mm, 901 104 382 02.
I haven't found the starter nut in my parts catalogs.
edit: Confirmed cylinder head barrel nut, 10mm, 901 104 382 01 or 02.
Jeff Alton 08-07-2007 11:02 PM
Doug is correct, same part number as a cylinder head barrel nut.
One may consider a flanged nut for replacement as getting at in the future is much easier with a hex head flange nut.
Cheers
