krd krd is offline
krd's Avatar
electrical dilemma
Let me start by saying that I did use the search function, to no avail. My turn signals do not work - with the headlights on the signals stay lit (no flash), with the headlights off the turn signals do not flash or stay lit. I connected an alligator clip to a ground point and then to the side of each turn signal bulb, and nothing. btw, I did replace the flasher. please help I need to get my car inspected and nice weather is expected. it's a 1988 - 911. Thank You.
1988 porsche 911 "CE" cabriolet
Old 04-04-2009, 03:54 PM
krd krd is offline
krd's Avatar
i'm getting desperate!!!!!!
Old 04-04-2009, 05:27 PM
Does your emergency flasher system work (you know, all four flashing at once?)
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-04-2009, 06:35 PM
krd krd is offline
krd's Avatar
only with the headlights or parking lights on, not with the key in the off position.
Old 04-04-2009, 08:23 PM
muck-raker
kidrock's Avatar
sounds like the relay needs to be replaced. my 2 cents...
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 04-05-2009, 01:21 AM
I believe the flasher relay is further up the electric chain than the turn signals?
If the flasher relay is kaput everything else down stream will be affected.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-05-2009, 01:29 AM
Almost Banned Once
sc_rufctr's Avatar
This sounds like a faulty head light switch. They do go bad.
Have you done the relay conversion on your head light switch?
(Main switching through external relay instead of switch)
- Peter
Old 04-05-2009, 03:24 AM
krd krd is offline
krd's Avatar
i did do the relay conversion on the headlight switch.
Old 04-05-2009, 04:19 AM
muck-raker
kidrock's Avatar
I thought it might be the switch too...but he stated he "replaced the flasher". I took that to meaning that he had already replaced the actual switch.
It might be worth a quick try to check that relay...switch it out with one of your existing (good) relays.
STONE
Old 04-05-2009, 07:26 AM
