HarryD's Avatar
A CIS Air Box Cautionary Tale
A few weeks ago, I went to start my CIS car and there was a loud boom followed by my being unable to start the car. Knowing I had a flapper inthe air box, I was sure I did not blow up my air box but something was not right.
I opened the engine room and saw that one of my 30+ year old rubber straps holding the air cleaner cover to the box had broken and was askew. I removed the cover and saw the flapper vavle lying next to the hole it formerly occupied.
I pushed the valve back into the hole and used some 3M Blue Tape to hold hte air cleaner in place and started the car. It started without a hitch.
When I got home, I cleaned up the old epoxy, cleaned the area with carb cleaner, and used JB Weld to glue the valve back into place. I ordered two replacement straps and installed them as well.
After waiting 2 days, I started the car for the first time. I noticed it started easier than it has ever and the idle was smoother.
I think the improvements came from the fact that, over time, the valve had developed a slight crack at the glue joint that allowed a small bypass of air.
Anyone who has one of these things should periodically check for failure of the glue and reglue as needed to ensure a leak free install.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-04-2009, 04:09 PM
great to know thanks ..
Old 04-04-2009, 04:21 PM
+1 to HarryD's post.
My 73.5, which was running smooth as silk, suddenly began to have difficulty starting (which gradually got worse) and a rough idle. After checking the usual suspects, it was discovered the pop-off valve had developed cracks and air leaks around the base, just like Harry's. Hard to see unless you looked and tested for a leak. Cleaned it up and reglued and all is well. This should be a periodic check, IMO, for all us CIS owners.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 04-04-2009, 06:43 PM
My first pop-off valve broke after 2 months. It was replaced under warranty.
Old 04-05-2009, 12:18 AM
grateful user
don gilbert's Avatar
valve
i have put in a lot of pop valves, and have found that black urathane(not silicon) will not ever leak and so far, one has never popped out. i have had several jb weld ones come loose, sometimes a month later, sometimes years, and when it comes out you are stuck most of the time.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-05-2009, 06:18 AM
