-   -   Engine removal issues (http://forums.pelicanparts.com/porsche-911-technical-forum/361232-engine-removal-issues.html)
Bullet Bob 08-09-2007 02:21 PM
A few weeks back my rubber centered clutch disk gave way and I am now in the process of repairing it. The problem is that I can't get the engine and transmission seperated. I am pulling the engine only and everything is disconnected including the shift linkage and clutch arm pin, and I still can't get the two apart.
I fear that some debris from the clutch may be wedged in there making it difficult to get the engine off the transmission. Any ideas? I am contemplating removing the four studs to free the engine a bit.
Thanks,
Bob
boyt911sc 08-09-2007 03:56 PM
Engine/trans Separation.....
Bob,
Have you removed the clutch positioning lever? This controls the shaft that hold the clutch release fork. It is a lot convenient to remove/install the trans and engine bolted together IMHO.
Tony
Por_sha911 08-09-2007 07:28 PM
What Tony said + you really have to work on it to get the two apart. I just did mine and we had to pull and "twist" it side to side to get it to work loose.
Blk95993 08-09-2007 07:46 PM
be careful with the clutch lever spring...sucker is wound up tight
zbph10 08-09-2007 08:16 PM
Did you remove the clutch release fork or is that the clutch arm pin your talking about? Take the engine and tranny out together. I played the same game my first engine drop trying to remove just the engine and I'll never do it again. Once I had the two out together they came apart a lot easier. Same going back in, easier as one unit. Good luck
