windshield antennae
My glass instaler forgot to hook up the windshield antennae to the radio wire. Does anyone know how to get to the antennae wire from inside the car?
911rudy |
AutoBahned
IIRC, there is a small hole drilled a bit off center in the bottom metal channel that the weatherstripping sits in.
If that doesn't help, then he'll have to fix his own mistake by pulling the glass out and doing it right... |
did he put the wire into the glass frame hole?
If you look in the trunk close to the passenger side hinge you'll see the antenna amplifier under the cowl. See if there is a small gage wire with a small plug just hanging unattached.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks guys. I finally ended up in the trunk where the amp sits. The wire was in but not pushed in until it locked. I got it seated. How in the hell would one replace that little amp?
911rudy |
