SC tempostat motor wire location?
I am looking for the white/green and green/brown wires that connect to the tempostat motor for the cruise control on a 1980 SC. The motor is gone but everything else for cruise control appears to be there. The wiring diagram shows the connection to be at T2k but I am having trouble finding out where T2k is exactly located. I have a feeling it is under the rear regulator panel but before I take that out and start looking, has anyone else seen these connections. Thanks.
Below are two pictures of the cruise-control connector bundle coming off of the cross-member wiring harness.
http://forums.pelicanparts.com/uploa...1186938063.jpg http://forums.pelicanparts.com/uploa...1186937992.jpg This is the chassis to engine harness bundle exposed (behind fuse/relay panel) with no evidence of the cruise-control wires. It appears the wiring harness splits close to the fire-wall. http://forums.pelicanparts.com/uploa...1186938007.jpg |
Thanks, Steve.
I poked around and have not found anything yet. I noticed that in the chassis to engine harness photo, it appears to show a white/green wire in the harness that looks like the same white/green wire at the cruise control connector. Is that correct? Thanks.
Looking through my old photos, that wire appears to be in the bundle that goes to the left rear external lights and appears to be a much larger gauge than the tempostat motor wires. The plastic connector shown above appears to correlate to the T2k in the wiring diagrams. As I recall, the tempostat motor has a pigtail connector.
The control unit for the cruise control is in the trunk so I assume the wiring comes through in one of the main wiring bundles via the fire wall. I can't trace my tempostat wires any further than the mid-line of the cross-member with everything in the way. There is a larger wiring bundle parallel on top the cross member that appears to include the right rear external light bundle and possibly the a/c and may be what the tempostat wires originate from. |
Thanks again, Steve. I will keep looking.
| All times are GMT -8. The time now is 07:49 PM. |
