New battery and now tach is jumping
Battery was totally dead yesterday. Replaced the battery, car started right up. I was out driving today and noticed the tach jumping occasionally at idle from 1 to all the ways to 6 and back. Is this a voltage regulator problem or alternator? Alt ligh has not come on while driving. Thanks. It's a 79SC. Where is the voltage regulator? Easy to replace? What's also crazy is two of my guages have fogged up or become cloudy since I put in the new battery
----------- Scott 79 911 SC - Green, 2014 cls63 amg, 1981 528i, 2015 lexus Gx, 08 xterra |
Anachronistic Anomaly
The voltage regulator is attatched to the alternator. That's on the flip side of your engine fan inside the shroud. If the alternator has never been replaced, you'll probably be better off getting a Carrera style alternator with the built in voltage regulator... one of those "while you're in there" things. Seems to be a pretty common problem. First, check all of your grounds, especially on the battery you just replaced. It could be something simple like that.
IG@ the_derek_whitacre |
Dead battery + jumpy tach = bad alternator or regulator. Do a search here on the board for the exact numbers, but IIRC, you should be getting 13+ volts out of the alternator at normal (~2000) RPM.
1984 Targa |
Not sure why the battery was dead. I hadn't driven it for almost 2 weeks. I tried to jump it but it wouldn't start. Gas/oil gauge is fogged. Temp/pressure guage is a little fogged. Tach is the only thing acting strange. Time to buy a volt meter I think! Thanks
alt/reg, for sure.
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Evolved
Well the fogged gauges would scare me. Can you tell if its condensation?...or smoke?? If smoked glass, you have wiring troubles and I would be unhooking the battery till I could chase them down! Good chance of short/FIRE!!
Don't fear the reaper. |
Must have been condensation. It's been really humid and rainy here until today. Left it out in the sun and the gauges are clear
Skunk works
964 RS-4 |
Skunk works
tested the voltage last night...13.5 at idle and a little higher at 2000rpm
drove to my parents, 20 minutes each way and no bouncing tach
964 RS-4 |
![]() came back a few weeks ago more consistently, so i replaced the alt. would i suggest delaying like i did? no.
Seems like one of the battery cables was loose. Tightened every thing up and no more tach jump.
Skunk works
great! - hope mine is the same easy fix
964 RS-4 |
