kwm kwm is offline
Suspension Bolts
I lowered the front suspension in all of 10 minutes yesterday. Then on to the rear, D'oH! Any tips in breaking the large bolts loose on the rear suspension arm. I was trying to frist break loose the forward most bolt that holds the ride height in place then the next bolt to the right that adj. the ride height. No dice on either and I did some pretty not-so-advisable things to try to get it loose. After a soak in liquid wrench I put my breaker bar on it and used a floor jack to jack against the handle of the breaker bar. It actually lifted the car off the ground and would not break the bolt loose. I stopped short of jumping up and down the back bumper while it was lifted off the ground.
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 08-13-2007, 10:04 AM
Let them soak overnight, maybe several days, before attempting to remove.
And / or use heat.
Old 08-13-2007, 11:06 AM
the the is offline
Are you sure you know what you're doing?
Old 08-13-2007, 11:11 AM
You do not have permissi
john70t's Avatar
Ouch. I think I tried that method once and it ended with the nut rounded-off and the breaker bar flying across the room and breaking something(hence the name.
-Try some heat from a Mapp or oxy/acet torch on the nut only which will expand its circle(don't get it cherry hot or it will temper though).
-Or use a 1/2inch impact gun, but give it a few taps clockwise first.
-Sometimes a few taps from a flat punch just smaller than the bolt will break the corrosion-bond. Not too hard though.
Funny anecedotes about lube: A driver brought in a trailer once with a sliding rear axle. I pulled the pin, he locked the rear brakes, and drove forward-as is standard procedure. Nothing. Just kept dragging the tires forward and back. After 10 minutes of that, I sprayed down the slide with WD-40 and it instantly popped loose.
Another mechanic would often "taint" his WD-40 spray bottle with Mavelous Mystery Oil (against MSDS regulations) which greatly improved the results on doors/cables etc.... Funny thing was, he'd accidentally leave it unmarked in the cabinet sometimes and it was impossible to use it as a drill lube anymore. Just kept spinin' and spinin'.
Old 08-13-2007, 12:02 PM
kwm kwm is offline
joh70t can I get a bottle of that mystery lube? Anyway, yhea I was exhausted last night when I got home from work but tonight I am going to lube them again for the rest of the week then try it Friday night with heat, and maybe an extension on my breaker bar. At least with me all logic and common sense flys right out the window then I get a stuck bolt. Plus it was like over 100 degrees this past weekend when I was working on it. Sometimes I just feel like a ravenous dog on stuck bolts and I just keep trying and trying and lets try this lets try that and they are never good choices in the literal heat of the moment. Oh well you live and hopefully learn and in my case hopefully with age you get more patience (first kid due in a few months...)
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 08-14-2007, 04:28 AM
+1 here. I think you should read up on lowering ride height before you start messing with the spring plate bolts. They make such a minor adjustment on ride height but will really wack out your rear toe and alignment settings. The only real way to properly lower your back end with stock spring plates is to re-index the torsion bars. When you pull those out you will see you need to address the spring plate bushings and, assuming you do it right, when all is said and done you will need your alignment done and car corner balanced again. By adjusting the front ride height you may have already ****ed up your coner balance.
Tony G
2000 Boxster S
Old 08-14-2007, 05:41 AM
kwm kwm is offline
Corner balance.....this isn't a purpose build track car it is a daily driver.... I am more concerned about rubbing the top of a speed bump at the grocery store than anything else. The 25mph on ramp is the biggest turn this thing sees on a regular basis.
83SC black on black
01 Chevy S10
08 Buick Enclave
Old 08-14-2007, 05:46 AM
AirCooledExcellence's Avatar
Doesn't matter if it's a track car or not! If your corner balance is out your car will not drive properly! You may have trouble with it braking unevenly, pulling to one side etc...
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 08-14-2007, 07:26 AM
Goldfinger
Mattcamp's Avatar
I used a seriously oversized rachet with a swivel, an 18" extension and a jackstand. The rachet was a friends garage sale score. I first tried a Dewalt impact with no success. Then we put the socket and swivel on the bolt.............put the extension on and put the jackstand under the extension where it clicked onto the rachet. (if your extension is long enough, you should be pushing down; not lifting up..........that should keep your car on the ground). It came right off. Keep in mind that this was no ordinary swivel/ rachet set. I didn't measure but it made my 1/2" drive rachet look like a kids toy.
Good luck.
1984-Carrera (pewter metallic)
Old 08-14-2007, 09:41 AM
Tired Member
DaddyGlenn's Avatar
+1 and all the disasters those problems can cause.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 08-14-2007, 09:56 AM
Originally Posted by kwm View Post
....After a soak in liquid wrench I put my breaker bar on it and used a floor jack to jack against the handle of the breaker bar. It actually lifted the car off the ground and would not break the bolt loose. I stopped short of jumping up and down the back bumper while it was lifted off the ground.
Those large nuts are one of the few places on my 911 that I'll use an impact wrench to loosen. They virtually unscrew themselves once they see me fire up the compressor and break out the I/R (600+ ft/lbs of torque) .
Old 08-14-2007, 10:03 AM
